Old 10-26-2003, 09:07 PM
Doc_Naughty's Avatar
Doc_Naughty Doc_Naughty is offline
Cobra Make, Engine: Factory Five, 302 EFI
Send a message via Yahoo to Doc_Naughty
Doc here again . . .
What type of manifold are you running? Some of the early type manifolds with the breather at the back for crankcase ventilation were known for leaking oil but usually only if the engine was developing high pressure internally. Make sure your crankcase is running under vacuum, not pressure. Improper crankcase ventilation will cause excessive presure and oil will leak out of all your seals.
Also, have you checked the transmission front seal for the input shaft or is it definately an engine oil leak?
Doc
"Pops" always used to say . . . you don't need to be smart, all the answers are in the books.
And when stopped for a vehicle inspection and asked why the brake pedal seemed to go just a little to close to the floor, the response was:
"I didn't buy this car to stop . . . it doesn't have anything on it that doesn't make it go faster!"
Brock Yates
