Old 10-27-2003, 09:53 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have bottomed out before with my Big Block but never with my small block so I am assuming you are running a big block engine. When I converted to the FE engine I got some new frame mounts that are almost a full inch shorter than the small block mounts. I am running 450 # front coil over springs which I have adjusted all the way up (two reasons: 1. Clearance 2. Handling). Also, I am running a Lakewood steel bell housing and it sits a full inch lower than my oil pan. I drew a line along the lower 1" lip of my bell housing and cut it off. You can still mount your inspection plate and add an inch of clearance too.
Also, I have a friend with a B&B that literally pulled the bellhousing off the rear of his engine when he went over a rail road crossing too fast and caught his bell housing. Now he is using heli coils to hold his bell housing onto his block.
Clois
"Let's roll"
"Be part of Something Good
