Old 10-28-2003, 07:02 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default BEST Rear Coilover Location
I have been looking at several rear coilover setups and noticed that many of the manufactures are running the same rear configurations but totally different locations for their rear coilovers. Some are mounted vertically on top of the rear axel while others will mount their coilovers at mid axel or even below the axel. Some are mounted vertically at 90 degrees, some will have a 20 degree inboard and 10 degrees lean to the front angle yet others go as far as 30 and 10 degrees respectively.
Is there a correct location and angle that truely best suits the Cobra or is it possible that all are correct given the amount of travel that is allowed.
An inquiring mind wants to know. I am looking at optimizing my suspension so I am starting my research here since this is probably the best source for real time knowledge.
Clois
"Let's roll"
"Be part of Something Good
