Old 10-28-2003, 05:58 PM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Had the same problem with my first set of side pipes. The glass packing has burned and the center pipe is all that is left. I drilled 2 holes on the back side of the pipe, about a foot a part. Then positioned the inner pipe over the holes, and tack welded it to the outside pipe. and filled in the hole with weld and ground it smooth.
Jack
XSSIVE .....
