Old 10-29-2003, 10:51 AM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
By the way A & C uses pipes and headers from Shell Valley.
I like the little bolt tabs Tony did. I basically used #8 sheet metal screws, (1) in each tube at a point where I could get to them after they were in. Which ever way you go make sure you have fitted the side pipes on the car with the body in place to get at least 3/4" to 1" clearance to the side of the body. You may have to jockey the pipes a bit to make them even. Good Luck.
Jim
OhioCobraClub.com
