Old 10-30-2003, 01:20 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Red,
One last note: The purpose of slip-fit exhaust joints as used in aircraft and race cars is to eliminate the need for gaskets or sealer. As I stated previously, a properly fitting slip-fit joint will seal itself. As the heated inner pipe, which is hotter than the outer, expands it creates a very tight joint. Yes, it may spit a little at first, but will seal tightly when at operating temp.
See the photo of the G7A/GT40 Mk IV CanAm car crossover snake-type pipes. These were very exotic pipes, having been fabricated from titanium. But the slip fit did the sealing. Note bolted tabs at joints.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
