Old 10-31-2003, 06:42 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
If you're thinking about that Crower cam, also consider the Isky 351360. Very similar lift and duration as the Crower but the Isky has 108 LC vs 114 for the Crower. I've never heard that Crower idle before but in general, the smaller the LC angle, the "lumpier" your idle. I'm running the Isky and I love it all the way around. Pulls very strong from idle all the way up to when the rev limiter kicks in at 6000.
On Desktop Dyno, I also get similar results for both. With my setup, DD says 500hp@5500, 511ft-lbs@4000 for the Isky and 472hp@5500, 530 ft-lbs@4000 for the Crower.
Chris
