Old 10-31-2003, 07:47 AM
coyled coyled is offline
Rocksnake, Does it have an IRS? If so, check the toe in. I run more toe in then most, 3/16 in. It seems to settle the rear and make it less twitchy. Also, generally, if you jump into or out of the throttle in a cobra in a corner, you can get oversteer. If its too stiff of a spring rate, it should step out under acceleration as well as when you lift. Good luck, scott.
