Thread: Az. Drag racing
Old 11-01-2003, 07:12 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Arm restraints are a good idea and cheap ( I can get for under 50 bucks) but the fact it is a = pop top, means all items pointed out are needed so TO MOST TECH guys it will not pass inspection. You will run under the time on a full pass but another way to skin cat is click it off early each pass. You get most needed info in the first few gears anyway, so just short shift out back door. The club has run and been given a waiver for group but... Hope Mike or Paul G jumps in here as they may have an inside path to help.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
