Old 11-03-2003, 08:20 PM
Keithc8 Keithc8 is offline
Default Four New Genesis Blocks Available
Once again we have four more Genesis blocks available. We will sell these with the machine work done ready to go together or we will build to suite. Once again it is hard to find a pump gas engine that will make over 600ft/lbs tourqe and 650HP but we can deliver them complete with Scat cast steel, Scat H-beam rods, JE pistons, hydraulic roller, Edelbrock stage 2 heads, Erson roller rockers or T&D rockers, DaVinci 950HP carb, MSD distributor and wires, Canton oil pan of the dyno for 15,000.00. We can also up-grade to a billet crank, billet rods, our CNC heads, single plain intake and add a little compression and you have a 800HP FE. Let us know if we can help.
Keith C
