Old 11-05-2003, 06:33 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Bernie:
I have Goodrich Eruo's (like the TA but much higher speed rating I think?? now no longer available sadly) on my Cobra.
I am currently running 21 Lbs air in the front and 22 Lbs air in the rear for normal street use (Cruising).
When I was at a higher air pressure, I found the ride quality too "hard" and too much feedback was transmitted to the steering wheel and arse.
The softer tire pressue has provided a nice ride quality.
Now, if you are using your car for other than general cruising, your tire pressure may need to be higher. I have read some old road test reports in which tire pressures (low) were the culprit in squirrely and squirmy handling on original Cobras.
I would be be very interested in the feedback from others as I am new to the Cobra.
Cheers.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
