Old 11-06-2003, 04:53 AM
BMK's Avatar
BMK BMK is offline
Hi Bryan,
Will see you there early on Saturday. Will play it to see what happens Sunday. Talk on Saturday with you.
Re your exhaust do the two hotdogs butt hard up or do you have them spaced apart on each side with exhaust pipe in between?
I went to a leading racecar exhaust place and the guy there walks out with a 18" hotdog wraps a rag around it and pushes it onto the end of the exhaust.
'It's not brain surgery', he says. 'Just space them as far apart as
possible with a piece of pipe between them'. He then suggested a larger diam piece between the hotdog outer caseing to hide the two hotdogs.
Something to think about. At the momment I only have the one 500mm hotdog on each side.
Will ring you to talk this one through.
Bernie
Bernie Knight
Mt. Gambier South Australia
Bernie Knight
