Old 11-06-2003, 09:40 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation When I cut open my filter recently, at 3K miles
All it had was a fine ferrous dust, maybe one teaspoon max. I had coolant seeping into my motor because of an incompetent Edelbrock Torker 2 install by my manufacturer, Vern Redel of West Coast cobras. My main bearings are shot, and the rod bearings have minor wear and look a bit glazed, although visually the crank and cam looks good, as well as the rest of the motor. Time for a professional hot tank and overhaul, including new rings. Sorry to give you this news, but you likely have quite a bit of damage in there and I would not run it another second. It will cost ya a lot more if a rod goes thru the block ! It looks like about $2 K at this point, including a professional dyno job, but it could have been a LOT more! Pulling the motor in a week or two....
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
