Old 11-06-2003, 12:37 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation I would not count on the oil pressure
As an indicator! Mine was 80 psi cold, 50 hot... no change from when new. But then the damage is almost entirely the bearings, and not any visible wear on the crank, etc... if your oil pressure is still high, then count your blessings and tear that motor down asap. You are gonna have to pull the motor and have the block disassembled, hot tanked and likely rebuilt. Yeah, I am sure you don't want to hear that any more than I did
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
