Old 11-06-2003, 08:26 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation One bit of advice to all members
When you change oil... position yourself so that you can see the drain plug CLEARLY, with a strong light...and loosen the plug enough to see what might seep out, without removing it yet. I did this over at Randy's transmissions in Tumwater Washington, on the rack (they are the best tranny shop anywhere IMO, and have allowed me to make mods in their shop. Great guys and highly recommended)
Well, anyway, WATER seeped out the threads first. Just a 1/4 cup. It was enough !!! Any water and you had BETTER take it seriously, do NOT start the motor, but instead pull the pan and check the main and rod bearings...You see the above pics!!! I will now do this for every oil change for every vehicle I own. You live and hopefully learn.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
