Old 11-09-2003, 05:07 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Al,
I won't use a FRAM filter at all. I lost an engine in the 60s because of one, but on the bright side your garage probably needed cleaning anyway. I use the WIX, Motorcraft, and once in a while the The Moroso Racing oil Filters.I have used the NAPA racing filter occasionaly which is made by WIX I think it is with no problem. I have a Moroso racing filter on on right now with a spare Motorcraft racing filter and also another spare Moroso. But I would rather use the Motorcraft and that is why the others are laying in the cabinet. when I cange oil again the Moroso will come off and the Motorcraft will go back on.
How did you blow oil all over the place? Was it not tight or did it split or something. You said past the filter, so did you have it tight and the gasket sealed?
You make me feel good. Anything I do you seem to top.
By the way, I can get you a good deal on a CASE of FRAM filters if you would like.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
