Old 11-09-2003, 07:26 AM
a427sc a427sc is offline
Default HD/Track coilover spring set for ERA or?
Two sets of Fronts: 1pr Eibach 350# 10"x2.5 (new in box)
or 1pr AFCoil 400# 10"x2.5
One set for Jag rear 4 Afcoil 525# 8"x2.5
These are in almost new powder coated condition. Will fit Spax, Carrera, Aldan etc coilover shocks that use standard 2.5" dia springs. The length will allow you to lower the car as you like without coil bind, yet still fall in the range for street clearance if you twist them up. The AFCoils will give an ERA a stiffer but not outrageous ride and definately won't knock out your teeth on the street. The Eibachs are more of a sport set for the front.
Will sell Fronts seperately in pairs, and rears as one set. Springs sell new for $75-100 individually, will sell for $70/front pairs, $140 for rear set.
NOTE: Springs don't know/care what end of the car they are on, and different mfgs specify different #/length for their applications. If the numbers add up for your car, they will work.
e-mail a427sc@aol.com
