Easy ad on,
Wilf is right unless you just want another switch to toggle.
Simply locate your electric fuel pump within 12 inches of your fuel cell. Mine is located on the frame above and behind my rear axel as is my fuel filter. If you don't intend to use your mechanical fuel pump remove it and block the opening off with one of the triangle shaped chrome/alum fittings sold at AutoZone. A little fuel line to your carb(s) and your done.
Wiring: Red wire to Accy side of ignition key to a toggle switch terminal. Then coming off the other terminal take that wire back to your hot wire of the new fuel pump. The black wire from the fuel pump is grounded to your frame. Your good to go. Or you could just bypass the toggle swithch but I like to be able to bump my engine when I am setting my solid lifters without having fuel to my carbs.
Clois
"Let's roll"
"Be part of Something Good
