Old 11-10-2003, 08:15 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Not uncommon to have a leak there, but that doesn't make it any more desireable. You have a 514, they have aftermarket cranks which don't have the same surface treatment on the rear of the crank where the seal meets it. If youe bellhousing is not dialed in to the crankshaft centerline, that can contribute to leaks there as well. Replacing the seal on the car is about a 50/50 chance of improving the problem. It could also be a galley plug, the cam plug, or jsut the rear of the oil pan seal.
