Thread: Oil Pan Gaskets
Old 11-10-2003, 03:45 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Oil pan gaskets, and valve cover gaskets. To seal, and re-use use gasket adhesive (Permatex), 3M trim adhesive, or Weldwood contact adhesive on valve cover, pan gasket side; and wheel bearing grease on the block/head side. Seals, doesn't leak, removes easily, and reseals again.
Been using this technique for 30 years.
