Old 11-10-2003, 11:51 PM
NZCOBRA NZCOBRA is offline
Cobra Make, Engine: Berry Cobra ,Tremec 5 spd . 408 windsor , double A arm 9"rear
Hi Nuke , I bought my tremec TR 4250 in 93 Its been great . Make sure your clutch fork to slave is ajusted correctly ,with a little clearance , are you getting enough travel out of the slave ? . Correct ratio of bore diameters ?
There used to be a book called ? The Brake and Clutch Manual . (or something) I think it tells you how much air gap there should be between plate and flywheel .this will make your shifting easier (hard to measure without split bell housing )
Best of luck Vaughn
