Old 11-11-2003, 06:45 AM
justa6 justa6 is offline
Default MIKE
I use a McCloud scattershield that is set up for BOP (Buick, Old, Pontiac) engine bolt pattern. Then there is a plate adapter that makes the trans "vertical". ie not tipped like the Camaro's.
I also use a "block saver" plate between the bell housing and the block as Stage II blocks are expensive.
Regards,
Bob
Johnex Cobra, Buick V6
