rdorman
Actually it is best to not start the engine once in a while unless you are going to allow it to warm up fully. The gas doesn't burn completely in a cold engine so you will get lots of residue of partially burnt gasoline staying inside the engine. You can do more harm than good doing this.
casaleenie
Got any beer?
Another thing I do is to change the
oil and filter in the fall. As far as placing the car on jack stands, this does give me the chance to check the brakes as well as clean up the suspension parts.
My engine builder suggested that I release the valve springs for those valves that are open. Only takes a few minutes and it certainly doesn't hurt them. Again, this depends on the type of springs and cam you have. Certainly not necessary on a mild hydraulic cam.
So far I have not had a problem with any Holley gasket leaks.
Mice? Don't leave the garage doors open in the fall and don't leave anything eatable laying around. These little critters can make a real mess if they get into a car. You can spread a few moth balls around on the floor under the car, they won't come close to moth balls. Don't put them in the car however or it will really stink in the spring. You can always borrow Jamo's cat.
Wayne
