Old 11-11-2003, 03:56 PM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Brake light switch trouble
I've got a hydraulic-actuated brake light switch on my Unique. The front brake master cylinder feeds a tee, which has a switch that screws down into the top of the tee. The reservoir is full and when I pulled the switch, fluid flowed out of the top of the tee. I feel reasonably certain that it's not the switch. I replaced it recently (the fluid level was low and there was insufficient pressure to activate the switch). I jumped out the circuit at the switch and the lights work fine. I put an ohm meter on the switch, it's not activating as I push the brake pedal. Anyone had a similar problem? The only thing I know to do is to bleed the front brakes, but they seem to work fine.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
