Old 11-12-2003, 03:49 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Many thanks for the info. I tested the switch I replaced earlier (I didn't throw it away) by putting an ohm meter across the leads and shoving a small screw driver into the port. I can feel the internal mechanism sliding and making contact, but I can't get continuity between the posts. I pulled the replacement switch from the car and performed the same test. Same results, no continuity. It would indicate I've got two bad switches. I will definitely seek the model you listed.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
