Old 11-12-2003, 05:16 AM
Dan Stryffeler Dan Stryffeler is offline
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Al,
I've been using the Fram PH8A filter for years with no problems, (it was the recommended filter for the remote unit that I have).
Considering going to an equivalent Motorcraft filter at the next change, based on all the comments in this thread and others.
Was pondering your oil pressure situation since I saw you on Sunday... still can't understand how the pressure goes up as the oil heats up. Mine always starts off at 65lbs or so and drops to 55lbs (off idle) as the engine heats up.
- Dan
