Old 11-12-2003, 08:32 AM
Default vALVE SPRINGS AND LIFTERS
Hi Guys I back off my rocker arm shafts when the car goes away for the winter. It weakens the spring and collapes the lifter if hydrolics are used. If the valve sits alittle open, moisture will get into the cylinder and may cause a rust ring. I have repaired motors the have sat over the winter without proper maintainance of oil fogging the engine just like in boats. Somepeople are LUCKY and never do anything, me NO Luck so I take no chances. Oil fog the motor still it stalls out. New oil in the crank case, Back off the rocker shafts, Jack the car off the ground, put plastic under it on a concrete floor for moisture. Drain the fuel injection system, Top of the coolant. Stablized the gas with a full tank. Rags in the side pipes, trickle charger on the battery with a 1 week timer. Cover and good for the winter. In spring reverse the process, Crank the motor over with the spark plugs out to remove the oil, Spray WD-40 in the holes and fire it up. New plugs and ready for the season.Check the plastic for any leaks and repair as needed. My car marks is Domain like an H-D. Rick Lake
