Old 11-13-2003, 04:24 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Speedo Gear Info Needed
I am running a 1975 Ford C-4 Tranny with a 3.50 rear end gear ratio and BF Goodrich Radial T/A's (295R50/15). The Tire Diameter is 26.7.
Two questions:
1) What size drive gear should be in the 1975 C-4? A seven tooth or an eight tooth?
2) Assuming the seven tooth drive; what speedo gear would I need. When I do the calculations it results in 18.54. Should I go up to the 19 or down to the 18.
Assuming an eight tooth drive gear the calculations come out to 18.9.
Thanks for any response you may give,
Tony
