Steve,
I do, but it's on another computer.
Here's the pertinent data:
5200 RPM HP = 438.8 TORQUE = 443.7 (Torque is Higher)
5300 RPM HP = 445.9 TORQUE = 442.2 (HP is Higher)
Thus the two intersect somewhere in between - you guessed it, at 5250 RPM.
The reason the above dyno does not show the intersection at 5250 is a result of different scales being used for torque and HP - the two vertical axis do not represent the same number scales. Due to that difference the HP and torque curves can't be compared on a visual basis. As to why one wouldn't always use the same scale, I couldn't say.
