Old 11-15-2003, 10:19 AM
strictlypersonl strictlypersonl is offline
Default Re: Is this really ERA 158??? Help!!!
I'm not saying absolutely whether the car was an ERA or not, but...
>>1. The side vents were fiberglass which was molded into the body, not the usual aluminum.
Early cars had fiberglass vents.
>>2. The front shock mount "X-brace" was made of square section tube, and not the round tube that I have seen on other ERA cars.
We changed to round-tube X around #350.
>>3. The body appeared to be black gell coat with no visible mould lines.
>>4. The billet hub carriers and lower control arms on the IRS in the picture had been replaced with stock Jag units..........
Our standard Jag suspension uses stock Jag hub carriers. A better question would be "Is the unit in a subframe?"
