Thread: wheel hopp
  #26 (permalink)
Old 11-15-2003, 01:59 PM
decooney's Avatar
decooney decooney is offline
Mike,
Spent some time with my machinist friend today. Took him a hub and some diagrams from BP along with some others... Looked at some options for inserts and insert/tools for mounting the frame bracket to box-tube frame. He felt it might be safe to thread the hub if its just for a dampner support. Also stopped by the Ford dealer to check out the dampner; but they were out. Time permitting, I hope to make a mock-up model once I get a dampner with spherical rod ends. May need to make that or have one custom made. Hope to get more time on it in a week or so. See Ya. Duane
BP,
Any other ideas on what might not be "set up correctly?". I'd prefer to fix the problem vs. adding more hardware to the car unecessarily. At first, I thought it was my tires aggravating the situation, but thats not the case with the varying tires showing common results... Shocks?, Adjustment?, Springs?, Subframe bushings?, sway bar or adjustment?, any other ideas? Meanwhile, I'll keep working on the dampner approach in absense of a solution or possible fix.
Thanks! Duane
Duane
