Old 11-15-2003, 06:25 PM
Sydney Sydney is offline
Cobra Make, Engine: Shell Valley, 351W
Hello fellas,
This is an interesting thread. I just did this about a month ago. After staring at the axle bearing for quite some time, I decided that the sealed bearing as is will seal about as good as anything else I could install. So I chose not to install any seals. Also on my 9" It looked like that the axle retainer might interfere with where the axle seal should go. I have the Moser axles with the bearings already pressed on, and the Wilwood brake set up. So far no leaks. (Knock on wood). I did use a lot of grease when I pressed the axle on.
Sydney
