Old 11-16-2003, 09:58 AM
Bluesman Bluesman is offline
I will give you a simple example:
My engine's total advance is 36 degrees at 2500 rpm.
I set the timing light knob at 36 and rotate the "just finger tight" distributor until the strobe shows exactly 0 degrees on the harmonic ballancer (crankshaft dampner). That is the big white chalk mark at zero. Don't forget to tighten the distributor when you are done. Good Luck!
Butler Racing Inc. 058
