Old 11-16-2003, 10:13 AM
Tinker51 Tinker51 is offline
Club Cobra Member
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
Thumbs up No expert here but...
This is what I have always been told. The spinner tools are not necessary but if you have one it should not be used for puting the spinner on. If you decide to not use the tool for removal make sure when you are hitting the ears that you keep rotating the ear you are hitting. Do not keep hitting the same ear. When removing the spinners use a lead or dead blow hammer. When installing the spinner snug it up by hand then start tapping the ears with a dead blow hammer, stop when the spinner stops moving. As stated before it does not take a ton of torque. Leave a little slack in the safety wire so you can easily see if the spinner has moved.
We have enough youth. What we need is a fountain of common sense
