Old 11-17-2003, 01:44 AM
Ant Ant is offline
Default Gearbox & body materials
Rebel1 ratios are the thing, I dont really need a great high gear so I can cruise at 130mph, so a 1.1 will do me on either 3.27 or 3.08 rear end ratio.
Are you contemplating the straight cut gear set with the G Force or the road helical cut gear set?
Grumpy, yep you are right I wish I had done the repair in polyester resin, mixing different mediums is not the best. I read where epoxy is better for repairs and bonds very well with polyester, but probably for glueing stuctures etc, hope it should be right, not a big area and I am going to post cure it, and then fill with Epifill or suchlike. Time will tell and the body shop said they will handle it if it becomes a problem.
A J. Newton
The 1960's rocked!
