Old 11-17-2003, 09:00 AM
Cal Metal Cal Metal is offline
Original Shelby Owner
With external adjustment, this is as easy as pie. You can hook up the dwell meter to the negative side of the coil; ground the black lead, fire up the motor and take a reading. The great thing about the GM design is that you can adjust it while the car is running. Should take you all of 20-seconds this way.
