Old 11-17-2003, 11:36 AM
cobra427hp cobra427hp is offline
Accel distributor uses GM points even in Ford & Mopar distibutors. Makes a snap for setting with external adjustment thru the access holes on the side of the housing, even has a disconnect plug for setting the points individually. No one has mentioned that the points are also offset with the secondary points opening just as the primary are starting to close, many people try to set the points with the primary on the lobe and screws up the secondary unless it is on the lobe when setting. A credit card is the perfect feeler gauge on the road as it is .016 thick. Where do you find books of matches these days?
