  #39 (permalink)
Old 11-17-2003, 04:23 PM
SVO460 SVO460 is offline
Originally posted by misfit41
11.6's ? thats one bad ass 4300 lb boat,thats as fast as maybe half the 2400# cobras running around,maybe you should check to see if a freight train hit you in the rear at the line. And to think of all that money ford wasted to build the Thunderbolt. Tk
You highly under estimate the 460 crate motors. They were under rated at 560 by Ford. A mag dyno'd one which they admitted was still tight and with an 850 out of the box at 577 hp.
I had some port work done by one of the best shops, Fast Times in Morton Grove, Illinois as well as port matched intake and a BG 950. I had 10" slicks and she was set up for launching, 1.6's short times. Do the math 4300 (with me) at 116+ is only about 520 rwhp, that's a little over 600 at the crank. My loose engine, port work and better/bigger carb was easily worth 25 over the crate motor fresh/stock out of the box. One of the mags did an article on one of the first crate motors sold. It went in a Torino they said was 4100 lbs but didn't indicate with/without driver, ran 11.1's over 122. They also didn't say what rear gear. They did say it was as delivered with the exception of 15 minutes of clean up with a sanding roll on the ports. Definitely less then my port work.
Naturally even with exact same combo's you can have a wide variance in performance. I was happy but still thought I'd do better by 2-3 more tenths with the extras I had I figured I'd at least 11.3's
I have an AVI clip, about 5 meg, clip of one run. This was before I had slicks and before I started dialing in the set up. It's not the best clip as this was mid level video capture technology from way back in '97, but you can clearly see the white wall tires, 225x75's (I dig sleepers), hear the engine via the open headers and see me lay waste to a modified LT1 Trans Am. The boards weren't working (if they were it would be hard to read with my friends crappy camera work) but this was a 12.6 around 112-114. I averaged high 1.90's on the street tires. The TA was a high 12-13 flat car I think just under 110 (07 to 09).
I can email it to you (anyone) if you like or if there is a place to upload it to I can do that too.
