Old 11-18-2003, 07:43 AM
Wade Chamberlain Wade Chamberlain is offline
Cobra Make, Engine: FFR2229K, Vortech-blown 306 (446rwhp, 442 rwtq)
You would typically use different pulleys to adjust boost on a supercharger. A blowoff valve usually isn't used like a boost controller. It's typically there to protect the throttle blades from high backpressure when you let off at higher RPM's. Most folks don't run a blowoff valve unless they're over about 6 PSI of boost.
Wade Chamberlain
