Old 11-19-2003, 02:30 PM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
In my opinion, you are starting from scratch.
If you can get me:
- tire diameter
- front and rear weights
- wheelbase
- peddle ratio
- number and diameter of caliper pistons
- coeficient of friction of pads (look at the edge codes and/or contact manufacturer or pick a new pad to buy of a know value and use them)
- mounting of calipers (fixed,sliding)
- disk diameters
- type of tires you will run
..... then I will be able to get you in the ball park. Close enough that the balance bar should take care of the rest.
Rick
OhioCobraClub.com
LondonCobraShow.com
