Old 11-26-2003, 01:17 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Todd:
Those are impressive numbers.
One thing that strikes me, is the low Volumetric Efficiency VE% numbers? You may want to query your tuner/builder as to why those numbers are so low.
VE = (Actual CFM / Theoretical CFM) * 100
Generally, you can expect a so called normal run of the mill engine (stock) to give 75% at normal maximum speed and about 80% at max torque RPM.
A stock high performance engine should have VE Numbers of 80% at Maximum speed and 85% at max torque.
A blueprinted or racing engine usually achieves 90% at max speed and 95%+ at max torque.
Often, reasons for low VE numbers are found in the air pump aspect of the engine. ie: constricted exhaust or air filtration that starves the engine of potential air.
You may be able to even get more out of this engine! That is pretty impressive.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
