Old 11-27-2003, 09:59 PM
408cobra 408cobra is offline
Default maybe comp ratio
I was thinking about your problem and I wondered if you ever CC'ed the cylinder heads and acurately measured what the compression ratio was when the motor was built. If its more than 10.8 to 1 this would cause this type of problem. Have you tried making the motor run rich to see if the temp comes down. It could be timing as was mentioned earlier.
