Old 11-28-2003, 10:13 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I use the the PreLuber from ESP Systems on my car. The preluber from <A HREF="http://www.preluber.com/">Engine Lubrication Systems</A> has an electronic module that activates the pump for 30 seconds when the ignition is turned on. The pump builds up 55 lbs. of oil pressure by drawing oil from the oil pan and pressurizing the oil return line from the oil cooler. That way all oil still passes through the oil filter before entering the engine. Oil pressure registers on the engine oil pressure gauge. The module also activates the pump again when the engine is shut down for up to 5 minutes. Keeping oil circulating while the engine cools down helps prevent "coking" or the buildup of sludge on the inner walls of the engine.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
