Thread: Air Cleaner
Old 11-30-2003, 07:10 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
I had a real problem with clearance and did two things that might help but the first is a damn expensive air cleaner fix. I replaced the Holley carb with an aftermarket injection system. The throttle body is almost 2 inches shorter at air cleaner base gasket area. Then I modified a Holley air cleaner that had 2 small square filters, one at each end. I removed them and made tubes that route to the front grill area and have K&N cone filters on them. Photo of my Cobray-C3 from Cobras N Vettes will make more sense than my desription. It has a 542 inch Dart gen 6 in it so space is at a premium. Aluminum dryer exhaust hose from Home Depot or the likes is very easy to bend and stays in shape so you can then glass your creation for looks and strength.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
