Thread: 5.0lt efi
  #22 (permalink)
Old 12-03-2003, 01:51 AM
Adrian S's Avatar
Adrian S Adrian S is offline
Cobra Make, Engine: G-Force, 351W, GT40 Lightning Intake, Toploader, Jag running gear, 3.07 diff, Autronic ECU
Hi Stuart,
I uploaded a bunch more photos of the things you were interested in.
The pedals I got were from G-Force but I wasn't happy with the pedal spacing (nearly kissed a wall coming onto the freeway ) so I took the assembly out and modified the gaps as well as lifting them about 20 mm. The accelerator pedal is the same one as yours and I ended up shortening this and welded a smaller pedal to it (from a Pugueot 504 at the wrecker !). This means the gas pedal is quite far over to the RHS but I figure thats where my foot will end up anyway. I will need to modify the pivot point of the gas pedal though as there is only about 40mm of travel from 0% to 100% throttle - too little in my opinion.
The plate that the pedal hinges off also need bracing as there is a bit of flex in it.
The fuel tank (70ltr) was fitted by Rob. As you can see from the photos, it could have been slung lower as the clearance is fine. It would also have meant the boot was roomier. I think I'll end up moving it eventually before I line my boot. Watch out for junk in the tank. It clogged my lifter pump which gave me a few headaches for a while. The tank currently attaches with two wide steel/rubber straps which mount to the top of the rear chassis rail. At the front, the straps mount to an angle bracket hanging from the diff.
The door latches & handles are again as supplied. I will get the car through engineering and then replace them. I'll use a XD/XF latch together with Morris Maxi handles (see picture). The current handle digs in the back of my arm (and this I find annoying after just 400 klms).
It's always easier to improve on something in front of you than it is to develop it in the first place. Hopefully you can use some of this info. Let me know if you need more info/photos.
Cheers, Adrian.
