Old 12-03-2003, 02:13 PM
coyled coyled is offline
541sc, no, if your under 12.00, the standard cobra roll hoop is not enough at most drag strips. If you truly have 650hp, it won't hook up well with street tires until your above 50mph. The bfg drag ta's work pretty well, I have used them. On the track, get slicks and it will hook once you get your damper and spring rates right. Good luck, Scott.
