Old 12-05-2003, 11:25 AM
misfit41 misfit41 is offline
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
I am sure lots of you guys know,,but unless you want alloy,,a drive shaft is a cinch to make and requires no special tools,,I have had good success with the few I have done,,best yet,get a used one with the proper yokes on both ends,grind off the weld,knock out the end,make a STRAIGHT cut with a band saw,tap it back in flush,then weld it up,balance is almost never a problem since both ends are balanced .
if you run into a yoke matching problem,ford old part number C3AZ E u joint has both standard ford yoke sizes on either side,so you can fit wide to narrow,,or vice versa..Tk
Tk
"this whole Adult thing just isnt working for me "
