Old 12-11-2003, 05:45 AM
blykins blykins is offline
OK....
The cam grind I came up with was a hydraulic flat tappet, 35-250-4, 240 and 246 degrees duration, .541", .544" lift, 110 degree lobe separation.
With a single plane and a 650cfm carb, 434hp @ 6000, 431lb-ft at 4500.
With a single plane and a 750cfm carb, 442hp @ 6000, 434lb-ft at 4500.
With a dual plane and a 650cfm carb, 403hp @ 5500, 417lb-ft at 4500.
With a dual plane and a 750cfm carb, 409hp @ 5500, 421lb-ft at 4500.
Desktop Dyno is pretty good on being right with the horsepower numbers....sometimes the torque is off a little though. When I did my engine, I came up with 490hp...it dyno'd at 484.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
