Old 12-12-2003, 11:10 AM
Zoom This's Avatar
Zoom This Zoom This is offline
Well, if you haven't attached your emblem(s) to your new car, I had great success using the 3M double sided tape on my SPF. I bought a packet of 4-5 squares that are 2" square in size, partially cut at the factory into 4 equal 1 inch squares. I pulled off one side of the tape and carefully laid my Cobra emblem squarely in the middle of the 2 inch square from the packet. Take a very sharp exacto knife and cut around the emblem as you hold it down onto a cutting board. Pull away the waste and take the exacto blade and neatly cut around the edge of the emblem at an angle so the tape doesn't show readily after the emblem is applied to the car trunk or hood. Remember, you only have one try to get it straight and true once you put it down. Looks fine and it saved me drilling holes and using barrell nuts to hold down the emblem. I just couldn't make myself drill into that beautiful paint.
