Old 12-14-2003, 07:04 PM
Rob_R Rob_R is offline
Club Cobra Member
Cobra Make, Engine: Superformance 496 FE side oiler TKO II
Default Weber manifolds on a FE
I have a 427 FE stroked to 462. I presently have a 2x4 setup on the motor. I also have a set of Weber 48mm IDAs sitting on the bench (the newly manufactured ones) from a previous motor project. I plan to install the Webers sometime in 2004. When the motor was built, I knew that I would eventually get around to installing the Webers so the engine builder installed a Weber friendly cam.
The question I have now is what manifold do you Weber guys recommend and why? I see that Pierce, Holman Moody, Inglese, and TWM all have FE IDA manifolds. Does Blue Thunder also make a Weber manifold? Whichever one I purchase, I will go with the 10° slanted pads.
Thanks in advance for any input.
Robert
